Porsche Crest Mystery Oil Leak!
I have a 1975 914 that I have never seen running before. I bought it from a guy that had gotten sick of restoring it so I picked up where he left off. So finally I get it all together and put the engine in. Before I try to start the engine I undid the coil and ran the starter to try and get some oil pressure. After about 10 seconds of cranking oil starts streaming down from under the oil cooler. :blink: Its no drip, its not dumping but I think if I were to run the engine for longer than 10-15 mins the oil would be all on the floor. I have replaced the oil cooler o-rings and made sure the mating surfaces were spotless on the cooler and the engine block. I have pulled the oil cooler out completely and put compressed air through it in a bucket of water and it doesn't look like there's a leak. I am at a loss. What in the world is my problem, and how can I fix it?
Also Thanks a million to those of you in this forum all your posts have helped me restore this thing immensely!
Levi
Old 09-13-2012, 01:08 PM
Kenny Powell's Avatar
...Oil pressure sender switch? or loose oil cooler?
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 09-13-2012, 05:29 PM
914 Geek
Check the oil pressure sender. Look all around it, is there oil there? When they leak, they can send oil running down under the cooler.
Look for loose oil gallery plugs. Those will be "interesting" to find if the engine is installed; if it is not then you can poke around and maybe remove the fan and fan shroud to get a better look.
--DD
Old 09-13-2012, 05:33 PM
