-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Removing gauge rings (http://forums.pelicanparts.com/showthread.php?t=740840)
chiefkt 03-24-2013 04:53 PM
I recently bought a used center console for my 1972 914 and the black rings around the face of the temp gauge and voltage meter need repainted. Is there an easy way to remove these so that I can properly sand and repaint them? I would appreciate any assistance you could provide.
Dave at Pelican Parts 03-24-2013 07:44 PM
Pull the gauges out of the center console; they're held in by rubber rings.
The bezel is crimped around a lip on the end of the canister of the gauge. Pry back that crimp and slide the ring off. When you're done, you push it back around the lip. The bent part sits against the rubber ring so it's not so obvious.
I've done the same with a tach and a speedo before, but not with the small gauges.
I am told that there are tools that help you do that job more smoothly. I don't know what they are.
--DD
chiefkt 04-07-2013 05:44 PM
Thanks. I appreciate the information and your time in making this reply.
Mike Bellis 04-07-2013 08:34 PM
To remove the face, I use a very small flat head screwdriver. Bending the crimp ever so slightly as I go around the ring. It should take 3-5 revolutions to do it right. If you bend it too much, it will kink or tear the metal.
