Porsche Crest 914 won't start
need some help, I am have a 1975 914 2.0, I pulled it in the garage yesterday and it ran fine, went to pull it out it wont start, it turns over and I can hear the fuel pump running but it wont fire. I put fuel in the throttle body turn it over at it fires up. Please Help
well after talking to my son who is helping me put it back together after having it painted, He decided to check the relays and the fuses in the engine compartment, could any thing in there cause this problem?
Old 07-31-2013, 10:01 AM
sportlichfahrer's Avatar
Check your trigger points for the FI in the distributor. If the fuel pump runs and you're not getting fuel it probably has something to do with them, wiring, or ECU.
'73 Silver 914 2056 D-Jet
'01 Silver Golf 1.8T Not quite stock
Old 07-31-2013, 10:29 AM
Also, this may help out too.
D-Jet Info
Old 07-31-2013, 10:36 AM
thanks for the info, kinda wierd it works one day and not the next, Will check it out
Old 07-31-2013, 10:51 AM
914 Geek
Check all of the electrical plugs in the engine bay. There are a couple that, if unplugged, will keep the engine from running.
--DD
Old 07-31-2013, 04:02 PM
Smile Dave u da man
Thanks Dave, checked and cleaned all the connections, guess what I fired up. Thanks all of your inputs
Old 07-31-2013, 09:14 PM
