-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   alt. rotisserie pick-up points (http://forums.pelicanparts.com/showthread.php?t=76405)
74914 08-03-2002 10:18 AM
Currently my 914's mounted to my rotisserie via the front and rear bumper mounting points. I'd like advise on mounting the rear somewhere else so I can work on the rear trunk floor. I got as far as building a setup with 2x2x1/8 mounted to the tranny points (no tranny mount/isolator). On each side, there's 2-2x2 spacers 6" long welded together , then a 20" piece welded to them. When I put my weight (150 lbs) on the ends, I could see the cross piece pulling against the floor, so I stopped. I appreciate any help I can get.
Ed
GWN7 08-03-2002 08:25 PM
The only way I could see doing it is to fabricate a U shape from the trans mounts back up to the upright of the rotisserie..............a lot of welding to build it and you would have to use thick wall 2" tube thru out, to support the weight.........and make sure you get good welds on all seams.
Personaly I'd just lift the car high enough to work on that area from both sides. This way you wouldn't have the rotisserie in the way at all when your working on the back or repair that area before you put it on the rotisserie. :)
derek_sf 08-04-2002 12:08 PM
you might want to see what CoolTool says, he has his 914 up now using the trans mounts in the rear and the into the suspension for the front.
74914 08-05-2002 07:38 PM
to CoolTool
Any pointers or more pics on mounting to the tranny mounts? I'm building a somewhat u shaped adapter to pick up those points. My intension is to bring it out from under the car, then up to about the middle of the rear panel, which is where my present adapter picks up the engine stand tube.
Ed
CoolTool 08-05-2002 10:33 PM
Ed, I am still trying to get some pics together(been having to work late the last several nights). As soon as I can get them together, I will let you and Derek know so I can send them to ya. On my rotisserie, I wish now that I had done just what you said you wanted to do. I just let the rear"head" sit under the heat shield, so the car will not go all the way upside down. David
