Question D-Jet vacuum advance
I'm replacing vacuum lines on my '74 2.0 D-Jet, and am confused about one thing- on the vacuum advance canister on the distibutor there are two connections, a 5mm on the distibutor side that connects to the throttle body, and a 3.5 mm on the ooposite side that evidently in '73 connects to the TB as well, but on the '74 there is no connection to the TB. Should this be capped off or should it be left open.
Thanks in advance for all the help this board has given me, one day maybe I'll be able to help one of you.
'74 2.0
Old 08-28-2002, 07:40 PM
anthony's Avatar
Yup, it's capped off on a '74.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 08-28-2002, 08:12 PM
3D914's Avatar
Anthony,
I don't believe you want to cap off the Advance side of the Vacuum cannister. It should have a short section of hose, but run it under out of site (for emission purposes), and do not cap it otherwise this will restrict the diaphram on retard side.
The advance side of throttle body should be capped though. Had this problem on mine. The PO's mechanic had used a small metal tube that didn't fit snug into TB. Pulled this out and put a solid plug in it.
Regards,
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 08-28-2002, 08:28 PM
