| Dave at Pelican Parts |
08-10-2014 10:43 AM |
I think the 944 wheels (except the 86+ Turbo) are the same part number as some of the 911 wheels. So they should fit as well as the 911 wheels do. Anything narrower than 7" should fit without real difficulty, though the rear fender lip on one or both sides may need to be folded flat or cut off, as long as you don't go too wide on the tires. (195 or possibly 205 should be OK, depending on camber and exact width of tire and so forth.)
The 944 spindles and hubs are completely different than the 911 parts as far as I can tell, and will not swap over gracefully.
--DD
