Fuel Octane
What type of fuel should I be running in my 76 2.0L fuel injection. I have been using 87 octane with ethanol and just put in a tank of 91 octane without ethanol. Car ran fine for about 10 miles then started running like crap. Wouldn't idle down and backfired a few time. Any thoughts?
914 Geek
The car was spec'ed for 91 RON, which is basically 87 AKI (which is what our pumps are labeled in here in the US).
Going to a higher-octane fuel should not cause any problems. It may be possible that the ethanol in the other fuel had been masking some other problem, but I think it still more likely that the poor running is a coincidence. Two things to check if the idle is too high: Vacuum leaks and ignition timing. If you have any air leaks, the D-jet system will idle too high. Likewise, if the ignition timing gets advanced the idle will go up. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
