What rear springs should I get?
I have a stock 2.0L that has stock front and rear swaybars. I will be getting new Bilstein rear shocks, and want to replace the springs as well. I am looking for something sportier than stock, but not so stiff that it is uncomfortable. I was thinking 140# or 165#. What do you think? Tires are 195-60-15 if that has any relavence.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
914 Geek
If you want to keep the rest of the suspension stock, I wouldn't go any heavier than 100 lbs/in. More than that, and the car will become (IMHO) too tail-happy. With 100s, you might think about disconnecting the rear sway bar and seeing what you think of the handling in that case.
I have 140s on my car, but have balanced those with a 19mm front sway bar and removal of the rear bar. It's pretty decently neutral. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Somebody makes a progressive 140#, I believe. That will give a nice ride on most good roads and give you a little extra when you drive a little harder. It's probably a good idea to replace old springs if they are original. They tend to sag after all these years.
Bilsteins....
Good luck finding the rear Bilsteins. I was told by Pelican they had no ETA on when they are coming in and supposedly they are backordered everywhere.
I had to go elsewhere....
