Porsche Crest Stock steering wheels?
What stock steering wheels will fit on a 914? How much modification is necessary? I am thinking of a 3 spoke or a 4 spoke.
1972 914/ 1.7 ltr, Saturn (chrome) Yellow, Brown interior
Old 10-23-2002, 08:03 PM
chrisreale's Avatar
I am confused (once again...) by what you mean by stock. Do you mean a stock Porsche wheel that came with the 914, or other models of Porsche. To the best of my no-ledge, there is only one wheel that fits on the 914 perfectly, and that is the stock 914 wheel. If you want a MOMO or Dino etc... you need a special hub adapter that bolts on. Pelican has it for about $50. Easy as hell to put on.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 10-23-2002, 09:09 PM
Porsche Crest steering wheels
What I meant by stock was what other factory steering wheels that came on other porsche models will work on the 914? I was thinking about the 911 /930 3-spoke or the 4 spoke wheels like on the 944 .
Old 10-23-2002, 11:03 PM
JWest's Avatar
Do a search, there was a thread about a 944 (I think) 4 spoke wheel of about '86 vintage that was put on a 914 recenctly. Pics and all!
Old 10-24-2002, 05:33 AM
rockaria's Avatar
911 wheels are a bolt on solution....
Hello,
I was able to bolt right on a stock 4 spoke 911 wheel from 1986. I had to do some fancy work to the horn contact end to get it all to work but it slips right on. I hear that 944 wheels have different splines and do not fit right on.
I took a 914 horn contact/turn signal canceler part from a used stock 914 wheel and put it into the oven at 275 degrees to get the plastic a little soft and then molded it around the base of the 911 hub. Now the 1 inch gap is covered up and the horn works as well as the turn signal contacts. As well the 911 wheel has an extra 2.5 inches in length I cut out of mine and had it welded so the wheel did not stick out as far. Though either way was perfectly fine, I prefered the closer to the dash wheel.
I have a lot more pictures here: http://www.zianet.com/landt930/landt914/
I hope this helps,
Christopher A. Landt
1979 911sc
1973 914 2.0
Old 10-24-2002, 07:34 AM
