-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   A/C compressor with no Refrigerant (http://forums.pelicanparts.com/showthread.php?t=85755)
Va914 10-29-2002 11:09 AM
Is it okay to connect an A/C compressor (belt only.. no power) up and run the car around?
I have not made hoses yet and will cap the connection to the compressor. The belt WILL be installed but no power to the compressor.
Sould I also change the refigerant oil in the compressor before it is connected to the engine?
Kerry
JWest 10-29-2002 11:32 AM
You can run the car just fine.
Va914 10-29-2002 11:48 AM
Cheers :)
sleepdoc 10-29-2002 12:14 PM
compressor
Hi
This is no problem because without power the AC clutch just spins free and doesn't turn the compressor.
The compressor will get flushed when you get the new system charged.
best Mark
