Hooking Up Starter Wire Confusion
I'm in need of some knowledge please.
I see that the wire from the battery and the wire from the alternator hook up to the long pole of the solenoid; and the yellow wire from the # 6 pin off the engine wiring harness connects to the male pin at the bottom of solenoid BUT, what connects to the 2 male pins at the top of the solenoid? I’m outa wires under here? 73 914 1.7 |
No worries
Nope, you've use up your allotment of wires.
Truthfully, I don't know what the hell they are for, but the other connectors are vestigial, like your appendix. They look like they serve a purpose, but you don't need them for anything. |
post a pic. are you talking about a booster/aftermarket solenoid. (to boost the key switch voltage) ? or stock set up?
| All times are GMT -8. The time now is 08:44 AM. |
