1.7 F.i.
I have a complete Fuel Injection system off a 70 , 1.7,914, it's going on 73 ,1.7 ,914 Is this a direct swap? or do I neeeed to worry about the E.C.U. or anything else . Thanks DaveSmileWavy
as far as i know, but a later ECU has a pot to adjust idle mixture and the early ECU doesn't
I don't think you'll have any worries at all if it is the complete system. You can probably even do a mix-and-match, to some extent, if you use all 1.7 bits...
--DD |
| All times are GMT -8. The time now is 03:53 PM. |
