Fuel Pump
I have seen this topic discussed here before but was unclear on the answer. Anyhow, my son has a '74 1.8 that is not running. Local independent Porsche shop says it is the fuel pump. There is a huge price difference between the 1 for 74 and the 1 for 75. Are they interchangeable? "Expert" "thinks" it will work. I have to find you guys are way more reliable than the "experts". So what do you all think?
'75 914 1.8 |
RETIRED
Should be the same....as long as it is the 75 1.8 fuel pump.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Where is the fuel pump located? If it's up front under the gas tank, it could be as simple as a bad ground connection. When Porsche moved the pump up there, they kinda "band-aid"ed it with a quick disconnect spot welded to the body. Problem is, the disconnect is steel and corrodes.
John Yellow '76 914 3.2 YPAF |
How Industrious are you ? 74' mounted in the rear 75' that was the year it was moved to front, completely 2 different fuel pumps you probably could make it work? Dave correct me if you will?
75' 2.0 w Ljet "I like the way she doesn't move in the curve's... and then she let's go!" |
