Bruce Allert's Avatar
Question A Test for Plug Wires?
Will testing for continuity tell how good a plug wire is? Or, is there another test that can be performed on them?
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 01-07-2003, 04:20 PM
pbanders's Avatar
Send a message via Yahoo to pbanders
Plug wires are cheap enough that they should be replaced on a regular basis (e.g. 20K miles). If there's any doubt, replace them.
Simple static tests of plug wires (e.g. resistance) do not assure that the wires are good. Secondary ignition testers are the best instrument to verify proper operation, and they're a lot more expensive than a set of wires.
Old 01-07-2003, 05:23 PM
I'm sleuthing an eratic miss and these wires are but 2 mos. old.
I had to take one of the new Bosch wires back due to one of the clippys within the plug socket was missing and it wouldn't stay on the plug. Since these are life time wires, maybe I should just take them all back & get replacements and that would eliminate a sector of the search.
thanks Brad.
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 01-07-2003, 05:30 PM
you should have x( 5k?) ohms resistence per foot. it dependes on the wire.
start the engine in the dark. you may see jumping arcs from the offending wires.
or the stupid test of running your fingers down them while its running. my favorite!
spray water down the wires out of a squirt bottle and see if the engine bogs.
hook a inductive timming light up and look for consistent fire.
look at your plugs/cap/button/points and plug connectors also
edit. got pertronix? the mallory unilite pick up i have in a boat required specific plug wires. ( no stainless steel or sprial core? don't remember what , but it was the kind i had .of course ) the feedback might be causing a miss
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 01-08-2003, 12:18 PM
