ruddyboys's Avatar
cylinder backfire
The engine seems to run fine (needs valves adjusted) but as ot idles I see the #4 clinder backfire thru the carb (dual webber 40). What could cause this.
74 LE "Bumblebee"
03 Jetta Wagon
Old 01-12-2003, 06:18 AM
lean condition. backfire up the carb ( rich is a backfire out the exhaust ) check for clogged idle circuit.
you will be running hot on that cylinder.
edit... leaking intake at head to manifold or carb base. spray a small amount of some wd-40 or cleaner around the mating surfaces. see if the idle picks up.
my bro likes to spray gas out of a cheap spray bottle. little scary for me.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 01-12-2003, 06:44 AM
