Fuel pump problems
No power to fuel pump for initial start if I jump fuel pump relay I have power both relays new ignition switch new
Fuel pump problems
Terminal 86 has no power terminal 30 does
With pump relay in and key on I have power to 86
Fuel pump pro lems
Thought I would make sure ground wire to fuel pump had a ground,with both wires disconnected and ignition off or on had test lite from positive battery to either wire and test lite came on meaning both were grounded don't get it
914 Geek
What fuel system? Carbs, injection? L-jet, D-jet, or some other injection?
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
