I HAVE A 1973 914 6 CONVERSION AND AM USING A 79 911SC 3.0 CIS ENGINE FOR IT, I HAVE ALL THE NESS IN REGARDS TO FUEL FILTER, ACCUMULATOR, AND FUEL PUMP. I DONT HAVE THE FUEL LINES AND FITTINGS TO THE ENGINE, AND FROM THE SUPPLY. WHERE CAN I GET FITTINGS, WHO MAKES THEM,WHAT SIZES ARE THEY. I WOULD LIKE TO RUN STAINLESS HOSE LINES TO AND FRO. I KNOW THE FITTING TO THE FUEL PUMP IS A BANJO. I KNOW SOMEONE HAS THE ANSWERS FOR ME. THANKS ENCLOSED PIC OF MY PROJECT
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
The fittings are hard to come by. It may necessary to take your fittings to a Hydr shop and have AN fittings brased onto them. The metal tubing from the fuel accum and the fuel filter is available from Pelican.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
JIM
EARLS. RUSSELL, AEROQUIP. AMF. NO ONE MAKES THESE IN THE CORRECT METRIC SIZE TO FIT UP TO THE PORSCHE FUEL LINES, AND THE BANJO FITTING FOR THE FUEL PUMP. GEEZ ARE THEY MISSING THE BOAT. SHOULD I LOOK FOR SOME USED LINES SOMEWHERE. DOES EVERYONE HAVE TO SWAP OUT EXISTING FUEL FITTINGS TO THE STANDARD AN. IT SEEMS LIKE ALOT OF WORK BRAZING OVER WRENCHING . I DID BRAZE FITTINGS ON MY FUEL INJECTED 2.0 YEARS AND YEARS AGO WHEN I WENT TO STAINLESS HOSE FOR THAT PROJECT. NOT MUCH HAS CHANGED IN 25 YEARS.
jim
i see pelican has all the lines, very spendy, i did some more research, i found on the web amf sells goodridge fittings that might do the job. stainless hose and anodized fittings look so much better and are less scary than those hard plastic crimp on stock lines. http://www.amfmotorsports.com/goodridgeprod.htm
If you just want to look pretty, it gonna cost you. I bought Earls black flexable hose for about $4 a foot. It's good for high temp and high pressure. Clamps on. Pelican has some nice gold zinked OEM clamps.
This guy might be able to help. He makes conversion kits for CIS. http://www.sandrail.com/millerfi
THANKS GREAT LINK CHRIS, I COULD GET LOST IN IT FOR A DAY. HE HAS ALL THE INFO.
DAVID
