Looks like I will become a new participant on this forum. I have bought a well-used 1987 924S 5-speed with 160k miles that has had good care but the seller said blew the water pump. The pump had only been replaced 25k miles before so it doesn’t sound like he was being negligent. The car was a daily driver (about 60 miles per day) and the seller has owned it for 14 years. He didn’t want to spend a bunch of money on it again. It has been driven coast-to-coast at least three times. He took it to a shop called RPM near him for maintenance and repairs. He described the coolant system failure as happening when was driving down “the mountain” where he lives. The temp started to rise and he saw some steam. He got off the road as soon as it was safe and looked under the hood. He saw steam and coolant coming out of where the water pump is located. He is confident that there was no engine damage although he hasn’t had the car diagnosed. It was parked about 8 mos. ago with a full tank of gas. What I do know: It is a no-rust, never wrecked car. Rough on cosmetics. It has nearly new Michelin tires and good brakes. The seller said it probably needs a tune-up since the gas mileage wasn’t as good as it has been in the past. It has a minor leak in the power steering system. It burns a little oil. He used to live in CA and the car passed emissions there which are more stringent than CO. Keep in mind that he told me all this after I bought the car so he had no incentive to misrepresent anything. The car is in VA and I'm in CO so I'm thinking of making it road worthy and driving it back. I have AAA, a cell phone and Pelican so I figure I’m covered. My son lives in NC, about 280 miles from the car's location, and has access to a good auto repair shop for free and a trailer. I’m not really sure what I’m going to do with the car so I only want to fix now what will get me home safely. I'd rather spend money on parts than shipping. I may have three or four days max to get everything done before I begin the trip back.I’m formulating a process and parts list to get it ready to drive nearly 1,500 miles. I am looking for your expert opinions on things that make the most sense to replace and do.
1982 911SC 1987 924S |
The newest of the noobs!
Um, 3-4 weeks maybe! I wouldn't do this, too many sources of pain in that car. At least trailer it the 280 miles to the free shop. Water pumps don't 'blow up', they'll leak coolant, or the bearing will freeze up. The latter of which usually takes out the timing belt, and subsequently, you have bent valves.
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
buy a spare cylinder head and have it refreshed ahead of time (valve job, surface ground flat, new valve guides and stem seals)...maybe $350 all in.
buy a remanufactured water pump and belt kit from ZIMS auto in TX. (sorry pelican) buy a head gasket kit from Zims or Pelican. have all these things ready when you arrive, get the car to the NC shop on a trailer. swap your fresh head onto the block, set timing and water pump and hit the road. sell the "old" head as a rebuildable core. with all the parts and tools on hand you can do a full HG, belt and WP job in a single easy day. |
Sorry for the linquistic snafu, grendiers. I, of course, wasn't speaking of it grenading or anything. Sounds like both of you guys assume that the head and valves are toast. Which also means the pistons could be toast too. Is this something peculiar about a water pump failure on a 944 (interference) engine? I'm pretty sure the car was running fine when he shut it off (other than the steam and coolant loss, of course) but I will double check with the seller. It didn't sound like there was interference caused by the timing belt slipping or busting. Other non-Porsche interference engines I've heard of with a water pump failure just lose fluid and steam up so this sounded like a classic seal or gasket failure. But that's why I'm asking you guys.
The seller is a REALLY nice guy and would probably let me leave the car there for awhile but I don't want to be an imposition. I would not try to do any repair to the car before getting it to the shop. I would trailer it to my son's place and then the shop. I would of course first determine if the belt is still there and in time. If after all the usual health tests like compression and leak down I would decide whether to just tow it home and plan to rebuild it. If the head is involved at all, it wouldn't be prudent to try driving the car 1,500 miles regardless. Then again I'm kind of a chicken. Thanks for the other hints on sourcing stuff and timeline estimates. I am curious why you recommend the rebuilt WP kit over new, v2rocket_aka944? I'm not opposed to saving money so I'm assuming you've had good results with rebuilt. I've known rebuilt parts to actually be better than brand new. Obviously you want the WP to last well past the next belt replacement cycle. This one didn't, obviously.
1982 911SC 1987 924S Last edited by rbuswell; 05-23-2018 at 01:23 PM.. Reason: Spacing |
Water pumps are usually first thing to fail when the belt was tensioned improperly. Even with auto-tensioners you must double check the tension since the belt will put too much force against the water pump pulley causing it to seize rather quickly. Every time I've seen a seized pump I've found that the belt was far too tight, but this hasn't always resulted in bent valves. In most cases the belt doesn't break however no coolant will be circulating causing the engine to overheat quickly and coolant to spew out of the overflow. I hope that helps!
1986 944 -Garnett w/Koni suspension 1987 924S -Red, 951 Swapped, ~300hp 1987 924S -Red, project car 1987 924S -White, Project car 1988 924S- Red, Bone stock, Daily driver |
Thanks, edredas.
The seller said the belt and pump had been replaced by a reputable German car shop about 25K miles earlier. Relying on memory, but I think the belt interval on a 944 engine is 40k miles so clearly something unexpected happened. Would overtightening/bearing failure also result in the coolant leak and steam coming from the area of the pump? Would the pump survive 25k miles after overtightening before bearing failure?
It all really depends on multiple factors, I've seen them fail after as little as 5k miles. That one bent the shaft without any leaks, while others lasted nearly 30k miles and the entire pulley broke completely off with coolant spewing everywhere. That said, I've seen even cheap pumps last well over 40k miles with proper tension. Some pumps I've removed were original and still going with well over 100k miles on them.
1986 944 -Garnett w/Koni suspension 1987 924S -Red, 951 Swapped, ~300hp 1987 924S -Red, project car 1987 924S -White, Project car 1988 924S- Red, Bone stock, Daily driver Last edited by edredas; 05-23-2018 at 03:56 PM.. |
water could be leaking out the pump, or the HG could have gone somehow - that was my "worst case" recommendation.
i have only ever used ZIMS rebuilt pumps on my own car, and the cars of my dozens of customers over the last 11 years wrenching on 944s. never a problem, and for $100 you can't go wrong. i have heard plenty of horror stories about people using the cheaper "new" pumps though. if you insist on NEW, get it from Porsche directly, not an off brand. |
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Thanks to all for your insights. I'll keep you posted when I actually have the car in my possession.
As I thought I might, I chickened out and towed the car home. The trip went pretty smoothly. This turned out to be a very smart move. Here's what I found out so far:
How’s it going with the 924?
Lots of encouraging things about the car and a few unexpected challenges:
That’s going to be a well sorted car. I’m pondering about doing timing belt myself or having local European shop do it?
... make sure you have the right tools. The ArnnWorx belt replacement tool set is a must have. It got a great right up in the May Panorama. It has already come in handy for getting the front pulley bolt off.
