Clunking sound from the rear end area
The other day I noticed a clunking sound coming from the rear of the car. After determining the whereabouts of the kids and dog, I continued out of the driveway. It was then I noticed that the brake warning light on the consul was on. At first I thought it might be a dislodged e-brake shoe but taking the rotors off ruled that out. The e-brake also appears to be working properly.
The sound comes and goes with speed, coasting, and in neutral. Here's a video of my turning the half-axle. The car is in neutral (manual transmission). It's only 15 seconds long and not knowing how to insert it, I've used a shareable link from my Google Drive. Any suggestions would be most appreciated. :) (And, yes, I know it sounds like 'Chain Gang'...) https://drive.google.com/open?id=1t17YZnCXlmoRHxoeKpcmU33XB7iUedbb |
Pull the rubber inspection plug and see if the drive shaft coupling is loose or broken. Verify that all of the bolts on the CV couplings (both sides) are intact. Pull the parking brake slightly on just to create some drag and see if that affects the sound. Hold the CV coupling in your hands and turn the shaft to see if you can "feel" the clunk to locate the area of the noise. Good luck with this.
It's really difficult to isolate the sound! Wondering if it isn't a torque tube bearing issue. I'm going to try to have a look with a camera. Thanks mytrpseven! |
I couldn't really see anything with the camera. I can rotate the driveshaft perhaps an 1/8th of a turn freely and then it stops. Not sure what to do next.
In listening to the sound on your video, at the end you can hear a metallic ringing sound, like something hitting a piece of tempered sheet metal. A similar sound is sometimes made when you hit the sheet metal splash guards/backing plates protecting the brake rotors. Can you rotate each wheel and check for interference or contact by anything with these brake shields?
| All times are GMT -8. The time now is 11:45 AM. |
