-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Timing Belt Tensioning Trouble (http://forums.pelicanparts.com/showthread.php?t=1007266)
Aero06 09-08-2018 12:59 PM
In the middle of tensioning the timing belt on my 1986 Turbo after a few months from the original change, and I'm having quite a bit more trouble with it this time around. I've finally got it back on after a bit of trouble (removed it entirely to change the front camshaft seal) but I can't get a read on the tension. Basically as I was tensioning it, the tensioner would only tension the length of belt between itself and the crankshaft, every other portion of the belt, from the water pump to the camshaft or from the camshaft to the crankshaft would be noticeably less tight. I pulled the flywheel lock off and gave the crankshaft a few rotations hoping it would even out the tension, but even now, I tensioned it to just under 40 ft/lbs according to my Krikit Tool, it seemed appropriately taught. I've cranked clockwise to the point where the mark on the camshaft gear has rotated 90 degrees, and now the length of belt that I measured between the crankshaft and the camshaft is completely slacked. I didn't have this problem before at all, has the belt been stretched out too much? I'm at a loss for what to do here, I imagine slack buildup will be less of a problem under constant rotation, but I don't want to risk damaging my valves if I'm wrong. Any advice for this? I can post pictures or videos to explain this if it can help anyone offer suggestions.
djnolan 09-08-2018 02:59 PM
As a sanity check on the cricket tension, there is the thumb on water pump pulley check and the 180 degree belt twist check. Check Clarkes for the details. I think both of these methods are based on the back side of the belt being taught and with the cam at TDC.
Also crank it through by hand at least two revolutions to make sure the valve timing is correct, and there is no interference from the valves.
mocha07 09-08-2018 03:07 PM
REFRESH the procedure;https://youtu.be/jpR6dWWiILk
