88_944's Avatar
Clutch fork: Throw out bearing Question
Well, after 2 years, I'm finely putting my engine back together. LOL!! Took the crank out and resurface the crank to fit over size main and con-rods bearings with engine on jacks. LOL!!
Never did clutch job before until now but does the Clutch fork goes under the Throw-Out Bearing? Something don't look right. The Clutch fork stays in where the Slave cylinder goes.
Help Thanks!
My Black 944
My Gaming Forums. Xbox360gen.com
Old 03-07-2003, 03:01 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Yup the two forks go under the throw out....the lip
and there is a shaft that goes though and holds the entire fork in place....
You should replace those needle bearings on the fork.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-07-2003, 03:08 PM
88_944's Avatar
Hey thanks! I replace those fork bearings and got a new clutch set, I change all the front and back seals. New belts rollers etc. I only spend about 1400 for all the parts. What a work out!
My Black 944
Old 03-07-2003, 03:13 PM
