Clutch fork: Throw out bearing Question
Well, after 2 years, I'm finely putting my engine back together. LOL!! Took the crank out and resurface the crank to fit over size main and con-rods bearings with engine on jacks. LOL!!
Never did clutch job before until now but does the Clutch fork goes under the Throw-Out Bearing? Something don't look right. The Clutch fork stays in where the Slave cylinder goes. Help Thanks!
Yup the two forks go under the throw out....the lip
and there is a shaft that goes though and holds the entire fork in place.... You should replace those needle bearings on the fork.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Hey thanks! I replace those fork bearings and got a new clutch set, I change all the front and back seals. New belts rollers etc. I only spend about 1400 for all the parts. What a work out!
