excessive fuel consumption
Hi all
I checked my fuel consumption and I nearly dropped dead..
Im currently getting 11-12 MPG.
Service was done about 1000 miles ago - so plugs and airfilter have been changed.
Car is a 2.5, 944 N/A.
Not hard driving either - always in and around 3500 rpm. Lots of Town driving - but surely it is far to high.
Any thoughts to why????
Cheers
Frankydoom
Old 03-13-2003, 05:17 AM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
running a little rich?
fuel regulator?
do a compression test.
you may be losing fuel.
what type of gas do you burn.. octane.. use 94...91 is minimum..
what type of plugs did they use.. stick with regular Bosch plugs, do not use splitfires or anything fancy.. they won't woirk properly with you car..
bad injector(s)?
My car is naughty
Old 03-13-2003, 06:34 AM
Oxygen sensor if your car has one?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-13-2003, 06:50 AM
suck my tail pipe
Frank B's Avatar
agreed.. check that also..
My car is naughty
Old 03-13-2003, 06:51 AM
WOW thanks for the quick reply .... Best way to check the oxygene sensor??
Old 03-13-2003, 06:54 AM
suck my tail pipe
Frank B's Avatar
Lawrence?..
My car is naughty
Old 03-13-2003, 06:56 AM
AFJuvat's Avatar
Your car does not have an O2 sensor (RoW\Eurospec)
Do you get the smell of gasoline anywhere?
Assuming you do not have a fuel leak somewhere, check the following
Distributor cap, rotor, plugs, wires, air filter
If those are all good, then check:
AFM, injectors, throttle switch, vacuum lines
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-13-2003, 09:20 AM
thanks all/AF - no fuel smell or any leaks - only thing i will try and change 1st is the cap and rotor... never thought about those
Ty
Frankydoom
Old 03-13-2003, 09:56 AM
