Clutch/Flywheel Replacement
'88 944 turbo: help!!! Starter is damaged (washers broken,shaft loose), suspect due to impacting damaged flywheel ring gear. Kicked started car, drove home. Tried to kick start later, heard "clang" below, wheels lock when clutch is released. Anyone had/know of similar problem? What improved clutch is recommended? Thanks for your response(s).
Old 04-05-1999, 04:11 PM
