ASE Master
Right Headlight Inop/Wiring Diagram Question
![]() RF headlight on my S2 inoperative on low and high beam. Ground checks ok at headlight socket. I have power on both sides of fuses 21 and 23. See diagram above. Does anyone know if C25 and C33 (circled) are part of a multi connector? Location? The only logical thing is that a connector came apart. TIA.
1989 944S2 (sold after 11 great years) 1980 911SC Weissach (bucket list car) 1975 914 1.8 (future restoration) 1993 968 Coupe 6 speed (new acquisition) |
C25 and C33 are pins number 25 and 33 on the C connector, located at the bottom of the fuse/relay panel. The dashed/dotted line that you see in the diagram represents the Central Electric (fuse block).
Good luck, George Beuselinck |
ASE Master
I guess I’ll be pulling that fuse box up, as I see no other place for an open circuit unless the harness got damaged somehow. Thank you George.
Trace wires from back of bulb. There's lots of movement in that area and wires will get crispy with age and snap 6-12" from back of bulb.
