wet sanding?
I've heard some fellow members here talk about doing this to there car and wanted to know what the deal is. what kind of process do you have to go through, would i be able to take on this project? is there a chance a can burn the paint. i wanna brightin up the paint but i dont think its needs new paint yet so whattya think?
1987 924S black on black , does it get any better? |
suck my tail pipe
Yry "Claying" your car...
get a clay pad and the appropriate polish.. you spray on the polish, then rub it with the clay,, and wallah.. it's as smooth as a babies bottom and then apply your favorite wax... drop a towel on your hod and watch it skate off.. super smooth and a deep lustre..
My car is naughty |
hmmm sounds like a good idea , i forgot about clay bars, ill give it a try thanks.
suck my tail pipe
that' be the way to go..I got my car in October, it lived under a tree for1 1/2 tears.. the paint felt like an armadillo's ass...I washed it.. (thoroughly).. then we clayed it dow.. it came back.. *new*. I wanna do it again when the weather breaks.... that is the only wa to go... You should stil buff it out but the lay will have the most noticable effect... got an Orange porsche?.. well, clkay it down and it'll be guard re again... !!
good luck...
My car is naughty |
Actually, I don't know if I'd put polish with the clay bar. The clay is used to remove deposits that won't come off with washing. I think that if they are that difficult to remove, they'd be pretty sharp and possibly gouge the paint with a polish on it. But I could be wrong, oyu might have found a way to shorten things up.
I only wet sand after i paint a car, I rarely ever do it after that unless it's an older car that needs a little paint restoration. If you really want your paint to pop, here's what i do every 6 months to keep everything clean and protected. It looks phenominal when it's done and you don't need to wax every month. It does, however, take 6-8 hours to do. 1.) Wash car with Dawn (with sponge and water) to strip old wax. 2.) Wash car with hands and Dawn (no water to dilute) to pick up anything you missed. 3.) Dry car with chamois. 4.) Use a clay bar and lubricant and clay the whole car, kneading the clay as you go. 5.) Wipe residue off. 6.) Wetsand areas that need it with 1500-2000 grit paper. 7.) With a buffer, buff entire car with Meguiars Machine Glaze 3 GC. 8.) Apply by hand, Klasse AIO 9.) Apply by hand, Klasse SG 10.) Apply by hand, Klasse SG, yes twice. 11.) Apply by hand, Klasse SG to areas that are prone to stone chips; hood, grille, fenders, mirrors 12.) Wax your car twice. I use P21S on mine. I did this on a black car for over 3 years, the paint looked brand new until the day it was totalled. Meanwhile, the jackass down the street that bought the same car as me and same color, well, his color faded. While my 1999.5 Jetta looked as good as new, his 2000 looked ragged. Compare his 33,000 miles to my 54,000 and the difference is VERY apparent.He prefers Turtle Wax.
1996 VW GTI VR6 Audi Berry/Black Leather |
verti, u ever get the info you needed?
forget about wet sanding. your paint is probably oxidized, go with a machine glaze & buff (not by hand, get a good buffer & foam pad).
If you have to wet sand, look up "Red Hill Abrasives", a company that sells al kinds of wood and metal working abrasives and polishes. They have wet&dry paper down to the 7 micron level. Used intelligently, this will bring back the finish in conjunction with a prduct made by Mirka which is a micro polish.
No affiliation, just happy with the products and service.
Bob S. former owner of a 1984 silver 944 |
I would never wet sand an old paint job. The clay works well. Mothers makes one and its does a great job removing foreign material from the paint surface. For fading and oxidation I would try paint cleaners first. If that doesn't work you can try rubbing compound or another suitable luquid abrasive. The Meguires three phase system works well.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
suck my tail pipe
My car is naughty |
or if its like mine, you just gotta poop on it
use a clay bar with a quick shine substance to get out any deposits and to make the paint feel really smooth. If you want to brighten your paint, use a buffer and some compound. If your paint is still pretty good and not too faded, use a foam pad, if it's really bad use a wool pad and then a foam pad. Either way I'd use the claybar. I've been detailing cars for 4 years.
PORSCHE: NOTHING EVEN COMES CLOSE Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels. 95 Infiniti G20 dark red metallic-for sale soon 87 BMW 325ic Bronzit, stock(for now) |
I have orange peel on the rear fenders, and rock chips on the nose. If I cleaned the car really good and touched up the chips would that look better when I have the car resprayed? As opposed to just leaving the ships as is.
I am thinking about having the car repainted by a Maaco type place here. They are going to prep the car somewhat, so I am not sure if that would help, or hurt? Lynn
83 944- Garage Queen 03 Mustang GT- I dont' do anything "Mild", do I? In the land of the funny underwear!!! |
no, touching up chips would not make it look better when resprayed, they need to sand down the paint to respray it. If you are going to go with maaco, I'd do the prep work yourself and just get them to shoot it, I'd get some decent paint on your own too. But it's good to touch them up for now to prevent rust.
The most important rule #1 top o the list unforgetable betternot do's is: When dealing with your paint, do not get in a hurry. Attn. to details go a long way on paint/body work.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Clay bar work good
Car shine Me happy
87na guards red(mine) 98 suburban(mine) 04 4Runner(wife's) |
