Time Serts-Porsche 944
I have a 84' 944 engine block that has one of the front cylinder head bolts that broke off in the block. The bolt is below the surface, so I can't grip the remaining part of the bolt with vise grips. Also one of the bolts for the water pump broke inside the hole too. I think Time Serts are my only option.
How hard is it for a newbie to properly install time serts? I have not heard back from the machine shops I have called, so might try to repair them myself. Thank you for your time and feedback!!
Old 04-07-2019, 12:49 AM
Disclaimer: I have no experience with time serts but believe they would be superior for your application. I have used helicoils in less critical applications with good results.
BEFORE you go this route, try overnight applications of PB blaster or Kroil penetrating oil, followed by left hand drill/easy out. I have been successful with this method. You must be able to get a good perpendicular angle on the drill bit. If the engine is in the car you probably will need a right angle drill for the water pump bolt.
Good luck
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 04-07-2019, 04:20 AM
Good luck
I will try this. I am removing the engine to do the clutch, seals, water pump, belts, etc. Just got to remove the remaining two torque tube bolts at the bell housing. Having a little trouble with those too.
Old 04-07-2019, 07:50 AM
9FF 9FF is offline
9FF's Avatar
Heat is your best friend for assisting in removing any studs or bolts that have been on there a while. Welding a bolt onto a broken stud both aids removing the broken piece with the heat and provides another method of removal.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 04-07-2019, 09:50 AM
Good Luck
It's something of a process getting a broken bolt/stud out. There are people claiming the best penetrating fluid is 50/50 ATF (automatic transmission fluid) and acetone, some articles with "scientific" torque numbers (https://app.aws.org/forum/topic_show.pl?tid=32013). I would start with some kind of penetrating oil, then using a center punch give the bolt a few serious raps to hopefully break it loose and prepare to drill it, give the penetrating oil time to work. Drill it and try the easy-out with vise-grips to slow twist (not a high rpm electric drill) to break them loose; as was said before heat is your friend. If you have the equipment the welding thing can work.
In the future when you encounter a suspicious bolt sometimes turning it in the tighten direction a degree or two breaks it loose before turning it in the loosen direction. Good luck.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 04-07-2019, 12:04 PM
Welding a nut to the remaining piece of the bolt in the block is a proven technique. Not only does it provide a means of turning the bolt, but, in the process, heats up the bolt to break it free. (Let me guess, it is one of the allen bolts at the front of the head, around the extension for the water jacket.)
Good luck, George Beuselinck
Old 04-07-2019, 12:26 PM
Politically Incorrect
onZedge's Avatar
The cylinder head studs are retained with a sealant that will REQUIRE heat to soften (this is some strong s***).
As 9FF indicates, welding on a bolt is the best way to remove the remainder of the stud after the sealant has been softened.
As far as timer-serts, I installed time-serts in all ten cylinder head stud holes in the block about 5 months ago, along with new Raceware studs/washers/nuts, head inspection/refresh, and a Cometic head gasket. I used the standard M12x1.5 universal head stud kit and did the procedure myself at home. I did have to add a few "parts" to the "universal kit", and modify the drill guide plate to make it all work.
I would suggest looking at the video(s) on the time-sert website. They make it look easy, but in reality, it is a little tedious and messy with the engine still in the car. BTW, Bel-Metric sells the time-sert head stud kits.
Edit - I will add some photos later this this week as time allows
Edek
'87 924S
'91 535i
Old 04-07-2019, 01:14 PM
Yes sir it is. I will try to take a good photo and post. The bolt broke below the surface. I wish it had broke above the surface to where I could get a grip on it with vise grips. Thank you to everyone for the
great suggestions!
Old 04-07-2019, 01:43 PM
I probably already know the answer to this question, but is it possible to leave one of the Allen bolts out? Has anyone tried it? I know the 944S only has one bolt at the front of the cylinder head, so just curious? Obviously the head studs are super important, but the two Allen bolts at the front don't have as much torque.
Old 04-07-2019, 09:22 PM
Coeur d'Alene, Idaho
So I have a bit of a procedural question here - a couple actually. Dan, you have no reason to believe you need Time Serts or any other product designed to repair damaged threads, right? Rather than the threads stripping, your bolts broke. So at this moment you have undamaged threads and broken bolts. Rather than trying this yourself, it is actually time to consider paying a professional welder to weld something onto these and unscrew them. Do that and you'll likely pay perhaps $200 for the extractions but then it's a done deal. Some welders have a mobile service, or if you're handy in this way, have a buddy just tow you to the welder you choose with a tow strap. Or if you're pulling the engine and have other means, bring the engine to the shop.
I just don't want to see you pay $150 for a Time Sert kit and tool, perhaps something for an extractor tool, and then still potentially drill crooked and mess something up.
Doug
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 04-07-2019, 09:23 PM
Doug
Thank you for the information. Good suggestions! I don't think there is enough of the bolt exposed to be able to weld a but. I did spray some penetrating oil as suggested. Also going to take a photo during the day light and post.
Old 04-07-2019, 11:45 PM
The remainder of the bolt does not have to be exposed. Check out the various youtube videos showing this technique, some with the bolt broken down into the block.
Old 04-08-2019, 03:23 AM
9FF 9FF is offline
9FF's Avatar
+1 I haven’t seen the job but I’m 99.9% certain that a professional welder can do the job regardless if any of the bolt is exposed. You’re assuming the worst without knowing the capabilities of a professional, go speak to a pro and be prepared to be surprised.
Mike A
Old 04-08-2019, 03:48 AM
Agree - welders and some mechanics are capable of small miracles with extracting broke and corroded bolts. If you live in a rust belt state you are in even better company as mechanics in those areas deal with them routinely.
Old 04-08-2019, 08:20 AM
I sincerely appreciate everyone who took time to respond and offer their advice. I have contacted a welder who makes house calls. Hopefully he will be able to help me.
Old 04-08-2019, 10:32 PM
Doug
It is tough to know if the threads are damaged. The way the bolt broke off makes it impossible to see the threads where the bolt screws into the block. Only time will tell.
Old 04-08-2019, 10:40 PM
I hope I'm wrong but I have a bad feeling about this welding procedure. They are going to raise the temperature of a steel bolt to near its melting point(2700 deg. F) in order to weld it and this is going to be done down in a hole in an aluminum block with a melting point of ~1270 deg F. Is it possible that the block will start to melt around the bolt hole by the time the bolt can be welded?
Old 04-09-2019, 01:23 AM
The weld method on an aluminum head concerns me as well. I think you risk warping the head. I am NOT a welder so it is quite possible I don't know what I'm talking about
Bruce P.
Old 04-09-2019, 02:56 AM
9FF 9FF is offline
9FF's Avatar
There are many ways to do it without any harm to the base metal or threads. I’ve used a nut centered on the hole and with the MIG nozzle centered on the nut I fill the nut with weld. The heat is concentrated on the center and almost never affects the base metal, but I suppose there is always a risk. There are even rods like Xtractalloy that are specifically for this purpose, like I said speak to a professional welder and you will be surprised what they can do.
https://youtu.be/L4zohssWS7I
Mike A
Old 04-09-2019, 08:42 AM
Thank you for the information. I sent a message to the welder who is suppose to come to my house Friday.
Old 04-09-2019, 09:01 AM
