what is this seal that came in my front seal kit
I am doing my first belt and seal job. i got the front seal kit from pelican. there is a white rubber washer slightly smaller in diameter than a lifesaver and slightly thicker. i don't know what it is for.
It goes between the camshaft housing "box" and the front "cover" behind the cam gear. The "cover" is actually the front bearing cap. You'll also have a large thick o-ring that will go between the two parts.
| All times are GMT -8. The time now is 12:08 AM. |
