924S Motor mount question
I'm going to be replacing my motor mounts tomorrow and I was wondering if I need to replace any of the mounting bolts or if I can just re-use the existing hardware with the new mounts? The mounts have never been replaced on this car so the replacements I have are the updated design. Didn't know if the hardware was different at all between the old and the new design.
Old 10-27-2018, 08:16 AM
I have heard it is a difficult job to get the new taller mount to line up and fit. Someone posted a method where the mount and the engine bracket were removed and installed as one to make the job easier. http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/935469-changing-944-engine-mounts-easy-way.html
I have never tried either method and if it involves removing the exhaust manifold, it doesn't sound easy either way, but I have some seriously bad dash rattling vibrations at idle I think are an engine mount collapse.
Old 10-27-2018, 10:58 AM
9FF 9FF is offline
9FF's Avatar
Pretty sure all the 924S had the newer designed mounts from the factory so it should be a straight swap. Iirc the old style mounts, without the 4mm washers, was only up to 85.5.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 10-27-2018, 11:47 AM
That's good to hear, I was worried I be half way through the job to find out I had the wrong hardware. Thanks
Old 10-27-2018, 02:59 PM
9FF 9FF is offline
9FF's Avatar
Originally Posted by matt1415 View Post
That's good to hear, I was worried I be half way through the job to find out I had the wrong hardware. Thanks...
Fyi I found the tsb from 85, so that confirms your later 924S should have come with updated mounts.
Mike A
Old 10-27-2018, 03:07 PM
That's awesome thanks for finding this
Old 10-27-2018, 03:18 PM
jhowell371's Avatar
djnolan thanks for posting that mount changing link. I lost a lot of obscure 944 links when my old computer crashed
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 10-27-2018, 07:31 PM
I wonder if anyone tried it to confirm it works? Did the exhaust manifold have to be removed?
Old 06-15-2019, 07:07 AM
The first time I changed mine was a pain and I didn't know what I know now about the difference between parts (I had bought the cheaper mounts), sad to say lesson learned and no fun doing a job twice...
Old 06-15-2019, 08:13 PM
