-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Ticking Noise Update...ABS Related? (http://forums.pelicanparts.com/showthread.php?t=1032479)
OK-944 06-17-2019 01:44 PM
An update on the ticking noise which seems to pulse at about half the crank speed, and only audible in first or second gear, sometimes while in neutral - at rpm's between 1400 and 2000.
Car is an '87 NA.
The sound goes away when the brake pedal is applied - and I'm thinking that there might be some sort of erroneous ABS signal causing this.
Does this ring any bells for anyone?
9FF 06-17-2019 02:06 PM
I doubt it’s abs related and pressing the brake pedal also affects the vacuum circuit and there is vacuum to a lot of components including fpr, damper and icv all of which can “pulse”.
It seems like you’re getting somewhere though but you’ll need to investigate one-by-one until you find the culprit.
