944T 1986 Steering Wheel
Does anyone know the proper procedure of removing the steering wheel. It doesnt have an Air Bag.
Old 12-31-1999, 08:25 AM
lm6y's Avatar
If it's like the early cars, remove the horn pad and horn contact wire, then remove the large nut, then mark the position with liquid paper so that you can get it back on in the right position, and then just pull it off. You shouldn't need a puller. Hope it helps.
Old 01-04-2000, 04:42 PM
