Brake piston blocked
Am trying to remove brake pads with pliers but brake piston is blocked - rusty and unused for a few years -
Any suggestions ?
Old 12-15-2018, 10:44 AM
if the rotor has a ridge around the perimeter, try sliding the caliper off leaving the pads on the rotor. odds are that you will need a new or working used caliper.
Old 12-15-2018, 12:13 PM
Time for new calipers. Don't trust your life to brakes that will not work properly.
Good luck, George Beuselinck
Old 12-15-2018, 12:44 PM
Try PB-blaster around the pistons. Will dissolve most things that cause that kind of lock-up. After getting pads out, push pistons out slightly by pressing on brake-pedal. Spray more PB-blaster around pistons and let soak. Wipe off gunk and hose off with brake-cleaner spray. Spray on some silicon lube and push pistons back in. If they don't slide smoothly, time to replace.
Old 12-15-2018, 02:51 PM
piston blocked
Thank you all guys for your suggestions : was thinking to put calipers down, sandblast them paint in red and mount again.
Unfortunately here in Sweden i can only find wd40 and i'll try with it to smooth piston
Old 12-15-2018, 10:59 PM
Northern Motorhead
wildcat077's Avatar
White vinegar will dissolve rust pretty quickly ... WD40 is at the low end of the rust removal agents.
Do a search on Google , all kinds of cheap home made recepies that work really well !
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-16-2018, 09:28 AM
Thanks vinegar and salt are certainly working better but aren't ther going to damage or dry the rubber gasket ?
Old 12-16-2018, 10:31 AM
acar24's Avatar
Take the hub off and put it on the grill. turn till done.
Old 12-16-2018, 11:56 AM
brake pads piston
Nope i like it mine..RARE
Old 12-16-2018, 02:16 PM
Northern Motorhead
wildcat077's Avatar
If your piston is stuck , more than likely you will need a rebuild kit with new seals anyways !
Cheers
Phil
Old 12-16-2018, 02:39 PM
Any suggestions ?
Wow, there is a lot of rust under that car. Are you sure that you even want to try and save the caliper? I see heavy pitting and metal loss in it and the suspension strut.
Are the rotor, caliper and pads all seized together? If so, then you will have to remove the caliper mounting bolts and beat the caliper off with a hammer. Otherwise you can't remove the hub/rotor from the spindle.
Once you get the calipers off then you can assess whether or not they are salvable. If you can't remove the pistons with compressed air or any other way, you may have to drill a hole in the caliper castings at the approximate center of the pistons and drive them out with a drift pin. Then tap the hole for a tapered plug to reseal it. Now you can examine the bores and pistons for pitting and other problems.
I don't want to be a "little Debbie Downer" but I wouldn't count on being able to reuse these calipers.
Old 12-16-2018, 05:01 PM
Northern Motorhead
wildcat077's Avatar
Yikes ... i just noticed the rust as well , what does the rest of the car look like ?
Cheers
Phil
Old 12-17-2018, 06:28 AM
acar24's Avatar
brakes
the inside pad should pry straight out unless there is a large lip on the rotor. if it absolutely won't move, chisel away the brake material until it will. once you have the pad out, stomp on the brake to get the piston to move before taking off. heat applied to the caliper with small torch or hair drier. Or
Old 12-17-2018, 10:45 AM
the rest f the car ...look for yourself...interior without a tear after 34 years ! dashboard included. I usually don't answer such ironical questions but some says irony is a weak sign of intelligence rust abunds on the left side of the car but i'd like to see what is left of yours if you leave it to snow, rain and sun for several years....
Old 12-17-2018, 12:24 PM
Northern Motorhead
wildcat077's Avatar
Chill out farfeller ... i was just concerned about the possible rust on the suspension parts.
Now , for your comment about "weak intelligence " , i will ironically leave for interpretation regarding your questions about that caliper ...
Good luck with your car !
Cheers
Phil
Old 12-18-2018, 06:50 AM
Whatever, but the caliper isn't going to move if the cap is on the master cylinder.
Old 12-18-2018, 04:33 PM
brake piston blocked
sold as is.....
Old 07-27-2019, 12:24 PM
