Replacement of Rear Wheel Hub
I have a rear wheel hub on my '86 944T whose flange is slightly bent causing repeated rear rotor warpage. I am replacing hub. Do I need to replace the baring as well? Hub is pressed into baring; baring pressed into aluminum housing. Anyone have knowledge of this?
