-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   A/C Compressor oil (http://forums.pelicanparts.com/showthread.php?t=1036825)
mytrplseven 08-07-2019 05:55 PM
A/C Compressor oil
Anybody know the amount and type of oil that should be added to a new a/c compressor? Mine is being delivered with shipping oil only and needs to be drained and reserviced before installation.
Pauld_94S2 08-07-2019 08:55 PM
Generally 3-4 ounces, add some oil to both ports, one at a time, and rotate the clutch to push the oil into the compressor body. Repeat until you have added all the oil.
Best to drain the new compressor and measure the amount of oil, then replace with the amount of the type you will be using.
If you are staying with R12, use mineral oil.
If you are charging with R134a then use POE since it is compatible with mineral oil as opposed to PAG.
