Send a message via AIM to TheCooler
Power steering
Recently my car has begun to squeek and whine as I turn my wheel at a stop or in 1st gear. I assume its to do with the power steering... maybe the fluid is low or a belt ..ill go check the fluid now but if it isnt that then what could it be? Also its a continious squeek when i turn it but when u let go of the wheel it stops. And it only heppens at slow speeds.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 03-28-2003, 08:53 AM
AFJuvat's Avatar
refill the reservoir, drie the car, turn the wheel full left and reight a couple of times
check for leaks
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-28-2003, 09:16 AM
The pressures are greatest when the car is motionless or going very slowly and you turn the steering wheel. The reason is that you turn the steering wheel much faster and there is more road friction when car is not moving or moving slowly. Higher pressure means more belt loading. You may only have a worn or loose belt.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-28-2003, 09:22 AM
I think Mr. Coppari's suggestion should be done first - check for a loose belt and adjust the turnbuckle if necessary and/or replace the belt. If that does not work, do as Mr. Juvat has suggested. They are both right.
Good Luck.
Stay Posted - more to come.
Old 03-28-2003, 10:25 AM
Thanks ill do that this weekend.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 03-28-2003, 11:25 AM
