Clutch Job
I just had my clutch changed, and I get a loud screeching noise (sounds like brake squal, or belt slippage) every once in a while. Sometimes it's affected by engine load, not all the time though. The weird thing is if it's doing it and I shut the engine down, it'll keep doing it until the last revolution of the engine, and when I start it back it's usually gone, not always thogh. I beleive it could be the throw out bearing, what do you all think?
That's what it sounds like. Take it back to the place that did the repair, and make sure that they got it right!
Oh, I am, monday...I'm just a little dissapointed, waited for about a month for the tranny to get fixed(under warranty) by German Transaxle, and had a clutch job, now it's got to go back again. I was just trying to get an idea of what might be causing it.
Turned out to be a weird vacuum line, my mechanic discovered this after taking the clutch apart, putting new pilot and throw out bearings...I picked the car up same day(dropped if off at 8am, picked up at 3:30pm)Thanks for the reply.
