-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Starting problem (http://forums.pelicanparts.com/showthread.php?t=1041563)
944Nick 10-01-2019 02:32 PM
Starting problem
After months of rebuilding the steering rack and pump and waiting on a new compressor I just finished installing the pump compressor and rack but I tried starting it up and the belts turn for less than a second but then stops and nothing happens
It's not the battery because the inside lights are fine and I recently replaced the battery
Maybe one of the belts is too tight?
djnolan 10-01-2019 03:32 PM
What is the battery voltage? It could need a charge after sitting for a while. You could also get it load tested.
944Nick 10-01-2019 04:10 PM
I dont have the equipment for that but I'll try jumping it
DannoXYZ 10-01-2019 05:33 PM
If you plan on doing further work on car, diagnostic tools are definitely needed.
https://www.harborfreight.com/7-function-digital-multimeter-63759.html
https://www.harborfreight.com/6-in-utility-caliper-63664.html
coupons here: Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, 20 percent off coupons, No Purchase Required coupons, toolbox coupons
