Re-useable??
Are these two parts re-useable??
http://forums.pelicanparts.com/uploads/part4184.JPG http://forums.pelicanparts.com/uploads/part4185.JPG thanks -Chris |
Strut mounts, unless they're worn or in bad shape, they should be re-usable.
Ahmet |
You really can't determine if they're good or bad unless installed(personally I need them to be). If you can wobble the mount they're bad, if not, they're good. To help out, buy new spacers that go inside of them, the little pieces of pipe.
Thanks for the help I've decided to replace the whole thing since they do wobble a bit. One more question tho, Pelican sells this as the strut mount http://www.pelicanparts.com/catalog/images/suspension_parts/944_suspension/4-02-00-11.jpg But that looks like the metal piece to the top of the strut. Can anyone dircet me towards the correct part??
thanks -Chris |
| All times are GMT -8. The time now is 02:54 AM. |
