Idle Speed 944T
What shout the idle speed be on a 944T? Mine seems low and is really noticable when AC is on.
Old 06-11-2000, 05:02 AM
stray15's Avatar
Send a message via AIM to stray15
I believe the proper idle speed is around 900 and 950. It usually will drop a little lower when the AC is on, but not too much.
Old 06-11-2000, 07:54 AM
stray15's Avatar
Old 06-11-2000, 07:55 AM
The AC units seem to draw a lot of power from the four cylinders. My rpm drops somewhat with the AC on too. I had a vibration with the AC on, but it's pretty much gone after installing new motor mounts.
Old 06-11-2000, 11:43 AM
is there any way to bump up the idle? When my AC is on, and i push the clutch in when coming to a stop, the engine almost dies before it finally catches itself, and jumps up to 750-800 rpm. My idle is normal with the AC off, it's only a problem with it on.
Old 06-18-2000, 07:38 PM
Turn the little brass bolt on the throttle housing to do it.
[This message has been edited by Lawrence Coppari (edited 06-19-2000).]
Old 06-19-2000, 01:42 PM
Goku's Avatar
My 944t does idle under 1k RPM's and does have a ruff time when I turn on the air conditioning, but doesn't die on me. Well i am glad that it isn't only mine. Any fixes would be great.
Old 06-23-2000, 12:22 PM
stray15's Avatar
Under the hood, on the passenger side right in front of the battery is a sticker with some information on it. The correct idle speed should be on there. Good Luck
'83 944
Tim
Old 06-25-2000, 02:58 PM
Send a message via ICQ to Penz944
Yea, mine also dies when I push the clutch in with the A/C on. I am glad it doesn't stall though!
Old 06-25-2000, 10:02 PM
Turn the little screw on the throttle body like lawrence said in the fifth reply. It fixed my problem!
Old 06-26-2000, 01:45 PM
