TURN SIGNALS DEAD
WHENEVER I WASH MY 84N/A THE TURN SIGNALS STOP WORKING FOR ABOUT THREE DAYS. AT THE SAME TIME THE FUEL GUAGE BOUNCES AROUND SOME. THE RELAY IS OK AND I HAVE CHECKED THE MAIN GROUND AND THE ONE BY THE SPARE. ANY ANSWERS OUT THERE?
Old 07-01-2000, 03:47 AM
Once again los ethe "caps".
Replace the ground wire, if you haver an older car they may have simply built up too much resitance, also look for a chaffing wire harness as this could also be your problem, and once again what year is your car?
The shortest distance between two points is in my car.
Old 07-01-2000, 08:13 AM
Oops!
Sorry I didn't notice before that you said you have this problem when you wash the car.
My first suspicion would be the drains in the cowling.
If you open the hood there is an area behind the firewall where the battery and central electric board (fusebox) are located along with a plastic cover under which is the blower for the climate control.
Anyway there are drains on both sides of the car that drain out behind the front fenders. If these get clogged they may be the cause of your intermittent problem as water can get into places that it isn't supposed to get into.
Hope this helps.
EDIT: actually with an 84 I'm not sure what exaclty it looks like behind the firewall, perhaps 1.2 gees can help here.
[This message has been edited by Pilot_951S (edited 07-01-2000).]
Old 07-01-2000, 11:00 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Well, it's pretty much the same, except there's no cover over the fresh air vent, and the fuse box is not out there either.
I'd check around the caps for the front signals (the wire caps, to weather proof, they're rubber), after you take them off, and pull back the carpet in the back to check that area. Make sure no water can run into your taillights either, from the exterior seal, or any water that might find it's way there on the interior, such as the hatch latch drains. Also check all wiring around the signals carefully, specially near drains. (I'm sure you'll find SOME corrosion if this has been going on for a while).
Besides that, check what Pilot says.
Good luck,
Ahmet
It's all the driver...
Old 07-02-2000, 01:02 AM
