-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   sway bars? (http://forums.pelicanparts.com/showthread.php?t=1055282)
911tracker85 03-18-2020 06:10 AM
sway bars?
as I dig through stuff found these two sway bars. I am pretty sure the large one is off the 951, but suspect the small one if off the 911.
if I am correct it looks like the large one is a M030 at 30mm.
it is for sale as is the other, but not sure it is for a 944.
now where the matching bars are hiding ....
http://forums.pelicanparts.com/uploa...1584536755.JPG
9FF 03-18-2020 06:39 AM
The large one is an M030 option from a 968 and will fit any 1985.5+ 944 or 951. Btw a 951 M030 option front sway bar was a 24mm tubular bar. The rear you have there isn't off any transaxle, so yes likely from a 911.
Now find the matching M030 19mm 968 rear sway and you'll have a set to sell. GLWS!
911tracker85 03-18-2020 08:19 AM
Actually I realized this is the M030 off my 951. pulled the engine to rebuild, almost done, and forgot I took it off. I got the F/R set when rebuilding the suspension on the 951.
suspecting I'll find the old ones in storage...
NOT FOR SALE.
