Holycrap what was that noise!!!???
Taken from rennlist racing digest, WOW!
Subject: The Power of Centrifugal Force From: paulamico@comcast.net Date: Tue, 8 Apr 2003 22:29:22 -0400 X-Message-Number: 1 Had to share this with the list. My wife and I took our 968 to VIR last weekend. We both drove with no problems for the first two days. In the last session of the second day I was driving up the back straight, I heard a bang, followed by a louder one a couple of seconds later, and the intense smell of coolant. I nursed it back to the pit and got it shut down. Looked under the hood and found a mess. The cooling blades on the alternator had let go (only two were still left in place). The damage was pretty impressive. - Two blades went straight up into the hood. They hit the center brace on the hood, put two holes in the brace and two large dimples in the hood. It was clear if they hit the hood they would have gone right through it. - One piece went into the frame rail nearest the alternator. It bent in a half-dollar sized section of the rail by about a half inch, including the corner, and punched a 3/4 inch hole in the rail. - A two-blade piece went the other way. It sliced the upper radiator hose completely in half like a knife, continued on to put a three inch split in the timing belt cover and kept going to tear up the balance shaft belt and gouge the balance shaft pulley (lucky it wasn't the timing belt). - Ricochet damage included various cuts and scrapes on the alternator belt and a chip on the Accusump. I've never seen anything like it. Neither had anyone else we showed it to. Any of you out there? That centrifugal force is something else. --Paul Amico |
Actually it was centripetal, not centrifugal, force that did it.
Mark |
I think you missed the point.
Wow..nasty the only thing that comes close is whern clutch explodes
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD ![]() 04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP ![]() http://www.eurocompulsion.net |
Mine blew a bearing two weeks ago and siezed, at the time I thought it was a huge issue, but in reading your post I now consider myself very fortunate.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Ornery Bastard
Centrifugal force is actually a non-existant entity. What is called centrifugal force is actully simple inertia as an orbiting object is always attempting to move in a straight line unless it is acted upon by an outside force (in this case, the centripital force that imparts an acceleration which creates that characteristic constantly changing velocity vector of an orbiting object). Centripital force is the force that counteracts inertia to make something orbit around a centerpoint. With that said, all that is left to say is wow, I'm glad that my alternator cooling fins never let loose. AaronM
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
A good argument for the larger diameter alternator "racing" pulleys.
As to the physics of the rotating mass: Think what would happen if one of the proposed large mass flywheel inertia storage flywheels decided to come apart!!! Ever seen what a dragster clutch/pressure plate looks like "after"?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
