Larry
1990 944 S2 Cabriolet deal/side moulding
I want to replace the side mouldings on my 944 S2 Cabriolet because the paint is bubbling up on some of the trim. Pelican Parts shows 3 part numbers. Do I need all 3 for each side or are the quarter panel mouldings the same for both front and back?
I also want to replace the decal above the rear bumper, but not sure how to remove the old one without damaging the paint. Any suggestions? ![]() ![]()
Larry
Not sure about the cabrio but my 89 S2 coupe has “16 ventiler” on the front strip. My rear also looks to have suffered the same blistering ![]()
You should be able to restore those side molding pieces. replacements won't be cheap if you go new. As for the decal, you will need heat, solvent, and a plastic scrapper to get the old decal off. It will come off in many pieces and it will take time but the paint underneath should be perfect.
