headlight troubleshooting
My driver side headlight doesnt work when I turn then on(DIM)(only the p/s headlight ). But when I turn it to bright, it works fine. Any thoughts
Old 07-21-2000, 10:33 AM
If I understand the problem correctly, one low beam is out but headlights work on high beam. Each bulb has two filaments. Your low beam has burned out.
Old 07-21-2000, 03:48 PM
lm6y's Avatar
Doesn't the car have seperate fuses for high / low beams on each side of the car? can't remember, and the manual is out in the car.
Old 07-21-2000, 07:33 PM
