944 Starting problems
I have a 87 944S that will not start. the engine turns over. i get good spark. but when i tested the fuel injectors i noticed that the electric pulse is very weak and not constant. any suggestions?
Is fuel reaching the injectors? Is your fuel pump working? There is a screw plug on the end of the fuel rail that you can remove to install a gage to check fuel pressure.
Good luck. |
I can find the fuel pressure tester at any local auto parts place, but none has the 11x1.5 mm adaptor called for in the Haynes manual. Anybody know of a particular brand/model fuel testor that works with the 944?
--Mike |
