Newbie
shifter angle
Just a general question. I have a shifter that is straight up and down, no gangsta lean like I see in youtube videos where they are going for a slight rake in the angle, like 80 degrees versus 90 degrees like mine. Mine is literally straight up pointing to the roof.
Coincidentally I am having intermittent shifting trouble going into first. I don't seem to have a lot of play sometimes it just won't go in without a few seconds of manipulating. I was thinking of buying a new linkage or the replacement shifter stem and tighten up, but I am wondering about my angle. Any thoughts?
85 Mercedes 300cd sold 98 323is sold 02 325i sold 86 944 |
This <link> has good info, especially step 18.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
This guy makes some great repair videos and in this one he's doing a simple one: replacing the shifter lever. He sets it at 85 degrees. I thought this slight rake was mostly for aesthetics, but could be wrong.
https://www.youtube.com/watch?v=UA3y-Xkj1QQ
1984 944 Zermatt Silver 1987 951 Flamingo Metallic |
Just installed a short shift kit in my 86 944. Shifts like a dream. I set the new shifter to 85 degrees back. (As per Clarks Garage). When I changed out the stock linkage at transaxle, I removed the stock setup all together and set new one to same specs before install. Required no further adjustments.
[QUOTE=Stoneguy;10844556]Just installed a short shift kit in my 86 944. Shifts like a dream. I set the new shifter to 85 degrees back. (As per Clarks Garage). When I changed out the stock linkage at transaxle, I removed the stock setup all together and set new one to same specs before install. Required no further adjustments.
Had one in my ex 944 worth every pennies spend.Grisp & short shifting.
Caraquet,N.B. Canada. |
Newbie
thanks. i did see that video and that is why i was questioning mine being straight up. I will probably to the short shifter linkage and replace the shifter at the same time.
Factory shop manual holds all the answers.
-Todd
1989 911 Targa |
Newbie
I bought and installed the only944 shift linkage (top piece, not the short shift linkage)
Amazing difference, about 90% better. Very easy to replace. I had a lot of left to right slop play and now it is very tight and crisp.
Shifter Angle Aesthetics: sign that the End of Days is nigh!
John
82 911SC coupe |
