968 transaxle noise level - normal
Hey all,
If cruising at 70mph with radio off and windows/roof closed, RPM steady, can you hear your transaxle? If so what does it sound like? Jason |
Well I hear something. Guess I need to tear into more stuff! 🙃
pinion bearing?
Seems like they all have it over shimed from the factory. need to replace bearings and proper set up |
the side cover comes off quite easily.
i bought a wired 'chassis ear' kit years ago which is quite helpful in pinpointing issues. 'bout a hundred bucks
Pile be the pinion bearing in transaxle or the diff bearings but if it’s resonating inside can a lot put your hand On the rear of the tunnel it could be the torque tube bearings going out there’s 4 in there and 30 years old a lot of these torque tubes bearings are getting noisy on these 944/968 cars
| All times are GMT -8. The time now is 12:47 AM. |
