Where can I get rear hatch struts?
The existing rear hatch struts that the PO put on my 924 are so strong that they spread the frame from the window farther every time I open it. Does anyone know of a company besides porsche that sells better working struts?
Old 04-25-2021, 06:10 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Pelican might have em...
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 04-25-2021, 06:21 PM
Northern Motorhead
wildcat077's Avatar
Do a search ... you can buy 94-95 Jeep Wrangler struts on Ebay that are 1/3 the strength of the OEM units.I use them on my race car due to having a lexan rear hatch.
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-28-2021, 11:16 PM
Anyone know if those jeep struts are still strong enough to "auto-lift" the hatch by way of the cabin switch? Not likely would be my guess...but seeing as how my hatch-release motor still works, I'd kinda like my car to retain this feature.
Old 04-29-2021, 12:23 PM
The jeep ones are OK but you'll need to modify them if you want your rear defroster and hatch light to continue to function since these both ground through the strut and the OEM has a metal connector to the body and the jeep has a plastic one.
I tried removing the Porsche metal ball joint and screwing it onto the jeep strut, but the threads were completely different. So, I got rid of the jeep ones and went with new OEM.
I have the OEM Stabilis version and the autolift is barely able pop the hatch in the cold winter months, so I imagine the jeep version would provide the autolift only when the gas inside is sufficiently warm.
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 04-29-2021, 01:25 PM
Hmmm...I'll likely go the distance at some point and do a hatch reseal. PIA I realize...but likely worth it if done with care.
Old 04-29-2021, 02:54 PM
Toofah King Bad
Rasta Monsta's Avatar
Care, schmare. I say go for it.
Old 04-30-2021, 07:21 PM
Purchase a killer Strosek fiber glass hatch kit and get the custom look, no glass issues, no problems, I might do it my self one day....Not oem, but bad to the bone, just the same..
Old 05-01-2021, 05:03 AM
I just one of the carbon fiber hood props a guy sells in the 911 section
Old 05-01-2021, 12:25 PM
Hey Rasta...was that an explosive event? Must've been spectacular!
Old 05-01-2021, 03:46 PM
Ernie944's Avatar
You can get them rigth here from ...PELICAN PARTS catalog...Why go into a hassle of modifying Jeep struts,get the one that are made for your car it's a ten minutes job to install, & then sleep peacefullyPrice is 19.85$ US.
Caraquet,N.B. Canada.
Old 05-01-2021, 03:50 PM
Well, as many of us have found out, the struts made for our cars are too strong and generally the stronger struts help increase the separation of the glass and frame.
Old 05-04-2021, 07:59 AM
Pauld_94S2's Avatar
"Anyone know if those jeep struts are still strong enough to "auto-lift" the hatch by way of the cabin switch?"
No, they are not. That way the force is minimal when the hatch is closed. Anything that will "auto-lift" will put strain on the glass frame. But they will hold the hatch open with no problems.
And "modifying" them only consists of moving the electrical terminals which will take you one minute per end. Real tough job (sarcasm).
I can provide the part number since I was the one who originally started using them over ten years ago and it's somewhere in Rennlist forum.
Old 05-07-2021, 09:25 PM
Northern Motorhead
wildcat077's Avatar
Yes they are still strong enough to lift a glass hatch ... with a little help
They are a Monroe item , P/N 901169 and i think they were something like $20.00 each
Cheers
Phil
Old 05-08-2021, 04:09 AM
