Going to my shop for the clutch job - recommended rubber clutch?
So I'm taking the plunge. I have neither the time nor the space needed to tackle the clutch job so I'm taking it to my trusted shop. He works on a ton of high end cars but still drives a 944 turbo, and spends a lot of his time at the track working on 911's, so i'd like to think he's pretty good.
He recommended the classic rubber clutch due to vibration noise and the smoothness. He said that given typical use the rubber disc will last plenty long. I understand the "it WILL degrade", but if it takes at a min. of 15 years to degrade, that is plenty of time by my standards. I'd like to do a bit of autocross and a few track days. Thoughts??? |
No.
Pretty certain they don't make the rubber center discs anymore - which means that anything you might find is "new old stock" and has already aged... There really isn't any appreciable difference in NVH in a rubber clutch car vs spring clutch car, from my experience driving both types... |
944 addict
I'm doing my third clutch conversion from rubber to new conventional style clutch and I've always used the Sachs package, i.e., disc, pressure plate and throw-out bearing w/shims. May also include new p/p bolts, T/B guide tube and, if it's leaking, a replacement rear main crankshaft seal (include new flywheel bolts).
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
As others have said go with the Sachs kit.
If you want to ensure a smooth clutch, have the flywheel and pressure plate balanced together. A local machine shop resurfaced my flywheel and balanced the PP to it for less than $100. |
Any other cars use a rubber clutch?
Is there any other car make that uses a rubber-centered clutch? What were they thinking when they gave that the green light for production?
1988 Silver 924-S Original owner Porsche 924S: The 944's cheaper, faster little sister.
Misunderstood User
+1 on the Sachs kit
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
The rubber discs lasted a long time and at one point I had an S2 with the rubber clutch and one without, if the car was not to be autoX and tracked the rubber is generally much nicer.
I have an S2 disc near-new with the rubber center if anyone wants one. I have had it in storage for, um, 17 years? or so since I got it with an S2 motor I since sold. Also have the PP. I have the flywheel and bellhousing too although those are desirable for 968 motor swaps. My notes say: "944S2 clutch, 8mm rubber center disc, PP looks new. Drive plate thickness spec: 8.1mm ±0.3mm Wear limit: 6.3mm" Lots of cars still use dual mass flywheels which are similar but more robust. -Joel.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
Thanks for the info!
Does a sachs clutch kit contain everything needed for the job? What are some additional while your in there things to keep in mind that don't come with a kit? I've got a ton of play in the shifter, so that is on the list. Last edited by JD159; 03-04-2017 at 07:51 AM.. |
re: linkage
Mini-project: tightening up shift linkage - Rennlist Discussion Forums and then this vendor took my instructions and commercialized them into great products ![]() Short Shifter - Only944.com Shift Linkage Arm - Only944.com Shifter - Only944.com |
You'll need a rear main seal, pilot bearing, guide tube, shift fork bearings and might as well pick up a new shift fork rod since the one in there is likely toast.
The clutch kit will contain the disc, pressure plate and throw out bearing. |
Here is my to-do list:
Pressure Plate Clutch Disc Throw out bearings Flywheel Bolts Pilot Bearing 2 Release Lever Shaft Bearings Slave Clutch Cylinder Flywheel Seal Throw-out Bearing Guide Tube Clutch Master Cylinder Clutch Fork Bearings and possibly clutch fork? Rear Main Seal Shift fork rod? Speed and Reference Sensors? What am I missing?
flex line from the clutch master to slave.
exhaust donut/gaskets and new nuts for the couplings. party liquor for the celebration when the clutch pedal comes up. |
Kessel run in 12 parsecs!
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
plays with toy cars
I have a rubber centered disc sitting on my shelf that I just pulled out of my NA a month or two ago. It was bought new in 2006 by the PO when he did a clutch job. 90%+ material left and the rubber is in great health. Free fiddy to whoever wants it.
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
@sausagehacker.....do you still have the rubber center disk available?
Sachs kit, I installed last year - smooth as butter. I would not go with rubber centered... especially if you dont put on many miles each year. The rubber may deteriorate before the clutch does.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP |
Toofah King Bad
Highly recommend Sachs PP and EPS disc from V E R T E X auto. Cheaper, and mo bettah (a rare combination).
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc Last edited by Rasta Monsta; 08-24-2021 at 11:23 AM.. |
You say that the PO purchased the clutch disc new in 2006. If that's true, I wonder when it was manufactured. I can't imagine Porsche producing these after the late 80s. The disc removed from my 1984 has "84" on the clutch disc. Is there a date on your rubber centered disc?
1984 944 Zermatt Silver 1987 951 Flamingo Metallic |
As others have said, rubber isn't the way to go, they won't last 15 years, I know that because they deteriorated 8n the 80s and the 944 didn't come out officially until 83( some 82s) and by 1986, Albert Broadfoot was buying spring loaded disks (a 911 part of a kit) to replace the rubber centered ones. Pretty sure he was one of the 1st doing that and had them listed in his ads in Excellence magazine back then.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
