Weak Brakes...Master Cylinder or Booster?
So...after having replaced all soft brake lines, rebuilding the calipers, installing new rotors and pads, and bleeding everything twice - the brakes are now only "so-so" as far as stopping the car. Very smooth, but just not great stopping power. Fine for general use...but I'd worry about a true "panic" stop scenario.
Brake fluid level remains constant...and I can find no leaks. Question: given the above...should I be looking at replacing the brake master cylinder, or the brake booster? |
944s have always had "soft" brakes... certainly compared to 911 brakes.
It may be that the pads are not aggressive enough or need to bed into the rotors better. I would do nothing for a month or so, then look at my options, starting with the easiest, which would be the master cylinder.
Good luck, George Beuselinck |
944 addict
I had what I thought was a great brake package in my restoration project: cross drilled rotors, Hawk street/competition pads, new master cylinder and stainless wrapped flexible hoses. I had also rebuilt my Brembo rotors, The brakes were hardly effective and downright soft. I replaced the booster, bled and re-bled the brakes and finally, after hearing about using standard rotors with semi-metallic pads vs what I was trying to use, and re-bleeding once more, I had BRAKES!
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
...are you sure it wasn't just the new booster that gave you what you needed?
Could be the pad type. I face same issue but running EBC Yellow on street now where i got them a lot warmer when it was just a track car. I plan to try more street pad first as i have rebuilt calipers , lines etc as well. Just doesn’t feel like it did
Sent from my iPhone using Tapatalk |
How many miles on these brakes now? Did you do proper “bedding-in” procedure?
If you think the booster is suspect, I will make you a deal on the one just pulled from my car, was brand new in 2008.
Brands & model
So, what brand and model rotors and pads did you use? What brand soft brake lines? I assume you lubricated the sliding parts and pins during your caliper rebuild, what lube did you use?
1988 Silver 924-S Original owner Porsche 924S: The 944's cheaper, faster little sister.
Brakes are actually starting to get better...still not quite there.
170K miles on the MC and Booster. Textar pads and Zimmerman rotors - not top dollar for the pads but I've had good success with this combo in the past. Not sure of the brake line manufacturer - but I got these through 944 Online and I trust them completely. At any rate...I'll give these a bit more time to see if they acquire any more bite. |
A booster diaphram generally gives an airleak sound when brake pedal mashed.
drew1 wife has 924 turbo |
Also worth looking into exactly how much vacuum is coming from the line connected to the booster. If normal, I would suspect the booster itself.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP |
Custom User Title
I struggled with that on my 951 and replaced the booster twice without getting any improvements. In the end, I found out it was a vacuum leak in the hoses underneath the intake manifold. I fixed that by doing a venturi delete and it's been great ever since.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Toofah King Bad
This is the preferred setup, IMO, so nothing wrong here. However, they do need to be properly bedded for optimal performance. And by this I mean actually following the manual. Accelerate to 30 ten times and brake hard to zero. Then 50. When you get back four wheels should be smoking.
Done.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
